AGUHR
Member
Offline
« on: September 07, 2010, 06:02:17 AM » |
My pumkin is not set up for an inner seal inside the diff, when I put a solid axle in the outer seal in the vaccum disco was too big for the TJ axle - does anyone know of a seal that works and a part number?
I kind fab'd my own seal by taking the stock YJ seal the the inner seal for the TJ and combined them by gluing them together with RTV and then pressed it in.
If anyone has any better idea on how to do this let me know.
Its working right now!.
Logged
94YJ SOA lift, 1" BL, XRC8 winch, Rhino Lined tub, custom rocksliders, 34 10.50 Super Swamper Bias, Aussie locker in front, Dirtworx fornt bumper. Home made items: Snorkel, CB, center console.
DodgeMudder
Member
Offline
« Reply #1 on: September 07, 2010, 07:20:28 AM » |
I'll have to look to see if I have the seal number for the seal I used.
Logged
neale_rs
Member
Offline
« Reply #2 on: September 07, 2010, 08:14:34 AM » |
Here's a number I copied from a writeup. I haven't tried it myself.
Passenger side seal for TJ shaft in YJ : 471763 a national number same for carquest and oriellys
Logged
AGUHR
Member
Offline
« Reply #3 on: September 07, 2010, 05:03:23 PM » |
this is the seal that will go in the vaccum disco area?
Logged
sharpxmen
Chief Squirrel BlowerŪ
Member
Offline
« Reply #4 on: September 07, 2010, 07:21:03 PM » |
you only need one seal if you get the TJ one piece
Logged
AGUHR
Member
Offline
« Reply #5 on: September 08, 2010, 05:12:55 AM » |
What do you mean you only need 1 piece with the TJ one piece? you talking about the outer seals for $75? I still want an inner seal just in case and my diff doesnt take the pass side seal, only in the vac disco area.
Logged
sharpxmen
Member
Offline
« Reply #6 on: September 08, 2010, 06:37:34 AM » |
YJ with quick disconnect (2 piece axle) has 2 seals on the passenger side, the TJ has only one (i'm not talking about the outer seals at the end of the tubes).
Logged
neale_rs
Member
Offline
« Reply #7 on: September 08, 2010, 06:47:29 AM » |
The one above is the one for the vaccum disco area. The part numbers I have for one that might fit next to the diff are: 470160 National , and Napa PN 11343. Some writeups report that there is no original seal next to the diff on the passenger side and that you might have to grind a seat for these. Others report that these seals went right in with no problem. I suspect not all D30s are set up the same way and you will just have to check yours to see how it is.
Logged
sharpxmen
Member
Offline
« Reply #8 on: September 08, 2010, 07:07:15 AM » |
i always thought the pass side on YJ had an inner seal and another seal by the disconnect - i might have gotten it wrong, not sure anymore. on the parts list for the YJ D30 there is a pair of inner seals and 1 called intermediate axle seal (that goes by the vac disconnect), what i was saying was that you only need the inner seals if you get rid of the disconnect (just like the TJ D30 has).
Logged
neale_rs
Member
Offline
« Reply #9 on: September 08, 2010, 07:50:38 AM » |
A seal by the disconnect housing would still be a good idea to keep water and crud from collecting there.
Logged
sharpxmen
Member
Offline
« Reply #10 on: September 08, 2010, 08:05:24 AM » |
for sure i don't know if the 1 piece axle has the shoulder machined to seal there though (but that's just me guessing so i could be wrong).
Logged
neale_rs
Member
Offline
« Reply #11 on: September 08, 2010, 08:13:15 AM » |
What I've read is that some people have polished that area or just sanded it with fine sandpaper and have reported that it has worked well.
Logged
AGUHR
Member
Offline
« Reply #12 on: September 08, 2010, 10:32:44 AM » |
ah, ok - thats where i was getting lost. I assumed (sorry for that) that all dana 30 YJs were the same with only 1 seal on the pass side. This is how mine is. I tried to put the TJ seal in the differential and it would not work. I'll buy on of the above seals and try it in the vacc disco if the one I made does not work or stops working.
Its interesting to know they are all set up differently though.
Logged
sharpxmen
Member
Offline
« Reply #13 on: September 08, 2010, 10:51:46 AM » |
that makes sense now, i thought they all had 2 seals on that side
Logged
sharpxmen
Member
Offline
« Reply #14 on: September 08, 2010, 11:34:47 AM » |
that makes sense now, i thought they all had 2 seals on that side  and i was probably wrong - i looked at an exploded view of YJ D30 and there is no inner seal so i'm lost.
Logged
